Hi. I want to play a game called “escape from Tarkov” but I can’t play as BT won’t give me access. I read a post on ‘Redit’ saying disable Web protect. I disabled it and everything works. BUT I don’t really want to disable web-protect. Is there anything else I can do???
I don't use BT Web Protect but according to these links you should be able to over ride it if you choose to however you will need to do this every time you get the warning. You can not set up a "safe site" or "ignore" list.
https://www.bt.com/help/security/set-up-and-use-bt-web-protect
Thanks for the help 👍
