Message 1 of 2
Firebase storage urls are blocked by the BT Web Protect
I started getting errors accessing any documents held in firebase storage.
I can see them in the Firebase console, but if I try to view them I get an error.
The exact error depends on which browser but it was along the lines of:
This site can’t provide a secure connection
firebasestorage.googleapis.com uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
After a bit of digging, it seems specific to the BT ISP and IMAP in the UK and caused by their BT Web Protect product. If I disable Web Protect from my BT account I can access the URLs again, but obviously, that is not a solution I can offer to our customers. (Similarly, if I connect via a mobile hotspot on my phone, all is well)
I contacted BT who suggested I email saferbrowsing@bt.com and ask them to unblock it, so if anyone else is having this issue please do the same - the more noise on this the quicker the resolution hopefully.
To the Firebase team - is there anything you can do from your side to expedite this? Firebase Storage is a huge part of our product and it simply doesn't work for anyone on BT at the moment.
Thanks in advance...😀
Tags (3)
1 REPLY 1
Message 2 of 2
Re: Firebase storage urls are blocked by the BT Web Protect
I doubt Firebase will respond on this forum. Perhaps better to contact them directly.
