Message 1 of 10
Firewall preventing printer wifi connection?
Hi - I'm new to BT Virus Protect (had BT broadband for a long time before discovering free McAfee) and have a macbook pro connected wirelessly to my BT Hub along with an Epson printer.
All has been fine until a couple of days ago, when I discovered that BT Virus Protect had never been running, so I uninstalled and reinstalled as per online advice, and all seemed well, until I discovered that my printer said it was "no longer connected to wifi".
Could this be because I switched on the firewall facility of BT Virus Protect?  Would invoking this be expected to block wifi access to printers?  Seem a little odd, since surely most customers would have this kind of setup.  I did try tweaking the settings by entering the printer's IP address in the list of allowed devices, but I'm alarmed at all the settings and not sure what I am doing.
Richard
9 REPLIES 9
Message 2 of 10
Re: Firewall preventing printer wifi connection?
have you tried reinstalling the printer
Message 3 of 10
Firewalls operate between WAN and LAN, not within the LAN.
Message 4 of 10
Hi, thanks for the brisk response - when you ask whether I've tried "reinstalling the printer", are you referring to the software/drivers etc that I installed onto my Mac when I bought the printer, just over a year ago?  If so, then no, I haven't....seems odd to me as a relatively naive user that every thing works fine for a year, and then the printer fails straight after invoking the firewall, seems almost unfair to point the finger at the printer software when the only thing that's changed is the firewall.  Uninstalling/reinstalling the printer software is not something I'm confident about, do you really think it's more likely to be the source of my problem than firewall settings?
Message 5 of 10
disable the Bt virus checker and see if printer works
Message 6 of 10
Even if it is not the cause of your problem my advice and that of others on the forum would be to uninstall BTVirusprotect. It can cause problems on some computers and is a resource hog. Do a search of the forum to see the problems.
There are far better free antivirus programs available such as Avast Free and AVG Free and given that you did not have it working in the first place would you miss it!
Message 7 of 10
I temporarily disabled the firewall, and the printer started communicating again with the laptop.
Message 8 of 10
That is weird, a firewall shouldn't prevent connections within a LAN.
Message 9 of 10
There is not really any need for a firewall, as your home hetwork is protected by the home hub firewall. In addition, if you have a Windows PC running Windows 7,8 or 10, there is an inbuilt firewall which protects both incoming and outgoing connections.
Message 10 of 10
The firewall is an internal one, and will filter incoming and outgoing connections to the PC. Not really needed these days, unless you are running Windows XP.  That was when Zone Alarm first came out, as Windows XP did not monitor outgoing connections.
An extra firewall is only going to be a source of problems. In this case its blocking the printer status messages, so it appears that the printer is not online.
