peterjenna777
Message 1 of 3
Free bt Wi-Fi/openzone
How do i use openzone when I'm not at home
2 REPLIES 2
Message 2 of 3
Re: Free bt Wi-Fi/openzone
Moderator
Moderator
Message 3 of 3
@peterjenna777 the easiest way to access it is to use the BT wifi app. Do you have your broadband or mobile service with BT?
If you do you can login with your BT ID and it will give you to access Openzone/BT Wifi hotspots for free.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
