peterjenna777
Message 1 of 3
Free bt Wi-Fi/openzone
How do i use openzone when I'm not at home
2 REPLIES 2
Message 2 of 3
Re: Free bt Wi-Fi/openzone
Moderator
Moderator
Message 3 of 3
@peterjenna777 the easiest way to access it is to use the BT wifi app. Do you have your broadband or mobile service with BT?
If you do you can login with your BT ID and it will give you to access Openzone/BT Wifi hotspots for free.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
