Message 1 of 6
HELP Certain websites or apps do not work.
Whenever I open an app like TikTok, Whatsapp discord, ect it does not load at all.
 On Pc i get this error when trying to visit discord.com
The connection for this site is not secure
discord.com uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Hide details
Unsupported protocol
The client and server don't support a common SSL protocol version or cipher suite.
Please help.
5 REPLIES 5
Message 2 of 6
Re: HELP Certain websites or apps do not work.
Check to see if parental controls are active
Message 3 of 6
Where would I find this setting?
Tags (1)
Message 4 of 6
MyBT
Message 5 of 6
Do the apps work if you are using 4g or if using another wireless connection such as at a friends house?
Log on to your MyBT and go to "Your Security" and check that "Web Protect" is turned off.
Message 6 of 6
For some reason everything works now but my upload speeds are terrible..
52 ping average
31.64 MB/s Download
0.46 MB/s Upload
How do i fix this, i use a smart hub 2 and a hybrid connect?
