dantheman12345
Message 1 of 4
HOW TO BLOCK PROXY SITES
Hi can anyone tell me how to get BT parental controls to block Proxy sites please
Cheers
3 REPLIES 3
Message 2 of 4
Re: HOW TO BLOCK PROXY SITES
I though you said you were moving to Sky?
https://community.bt.com/t5/Broadband-Extras-from-BT/Re-Parental-Control-not-Working-anymore/m-p/151...
Because of the large number of proxy sites, its not possible to block them all, unless you add each one to the blocked list on BT Parental controls.
The same goes for VPNs.
The only way would be to only add the sites you want to allow to a "whitelist", and block everything else.
You would have to keep adding to this whitelist, but you would have full control.
Every other category would have to be blocked.
http://bt.custhelp.com/app/answers/detail/a_id/46768#filterlevels
dantheman12345
Message 3 of 4
Hi!
I decided to stay because the controls came back online and finaly worked.
Why doesnt BT have a blocked word like my router has ie "proxy" setting? that would work
Jonkarra
Expert
Message 4 of 4
The problem is simple without deep packet inspection you're reliant on static lists of IP addresses acting as proxies. Deep packet inspection is prohibitively expensive, if you wanted to block proxies working over HTTPS you'd have to decrypt all HTTPS traffic again prohibitly expensive but also how many people would be happy with BT being able to decrypt all of your encrypted communications?
