Hi , I have an iPhone and downloaded the bt wi-fi app and installed the connection profile and it says it’s verified but it will not connect to or send me notifications to join a hotspot, I have uninstalled the app and installed it lots of times over the past few months but still nothing so any help to what I am not doing right would be appreciated
Solved! Go to Solution.
You don't actually need the app, it just automates the login process. Just connect to the hotspot and enter your login details in the screen it launches. Select BT Broadband in the 'Account' dropdown.
Thanks for the reply I’ll try that next time I’m out but just the not getting a notification to say I can join a hotspot that I’m not getting
No need to wait, just try it with your own hub.
Thank you
Hi that’s the problem it does come up with log in details but when I try it keeps saying incorrect username or password but I know I’m using the correct one as I can log in to bt with it , this has been happening for a long time now
Are you sure you are selecting BT Broadband in the drop down, it defaults to BT Wifi
Hi thanks for the reply next time I am out I will check that but can’t remember seeing bt broadband as one of the options but will check and make sure
As I said previously, there is no need to wait until you are out and about, just check that you can connect to Btwifi transmitted by your own hub
