Caher
Message 1 of 2
Hotsports in the UK
Hello,
why is it so difficult to use the BT service when out and about?
I find a BT wifi then login using my credentials and then it is acce[ted. But if I close my phone or stop using it for a period of time I have to go through the whole login process again. This can be as little as 2 minutes after prior use.
It's not my phone as it's my 3rd Android and they've all had the same issue.
1 REPLY 1
Message 2 of 2
Re: Hotsports in the UK
Download the BTWifi app and use that. It should keep you logged on until your are either out of range or after a couple of hours.
