One of our household devices is a Samsung Note 2014 which runs Android 5. What anti virus do you recommend as the new BT Virus Protect from Norton needs to be android 8 or higher?
try something free like AVG
The up to date free anti virus such as AVG do not support Android 5 either.
quick check and can't find one that supports the old android 5 - just out of date now
Do a search on the Google Play store and you will probably find a few Anti Virus apps that will meet your needs.
Thanks for the feedback. Looks like you cannot get an up to date anti virus for an old OS like Android 5.
