jmedwards
Message 1 of 4
How do I report poor service in a BT Openzone hotspot (Starbucks, Hampstead Highstreet)?
The BT-powered wifi at my local Starbucks is apalling: can't cope with more than 3 users connected at a time. When I report it to Starbucks, they say "It isn't us, it is BT: please contact them". I can't find out how to report a hotpot issue.
When it works:
I can always connect, but actual connectivity is near-useless:
Jamess-MacBook-Pro:~ jamie$ traceroute bbc.co.uk
traceroute: Warning: bbc.co.uk has multiple addresses; using 212.58.244.20
traceroute to bbc.co.uk (212.58.244.20), 64 hops max, 52 byte packets
1  10.14.183.1 (10.14.183.1)  538.069 ms  488.480 ms  358.964 ms
2  192.168.68.34 (192.168.68.34)  492.736 ms  527.631 ms  500.505 ms
3  192.168.240.2 (192.168.240.2)  496.136 ms  804.260 ms  385.857 ms
4  192.168.134.2 (192.168.134.2)  378.563 ms  357.681 ms  473.548 ms
5  192.168.71.45 (192.168.71.45)  588.783 ms  494.214 ms  440.090 ms
6  192.168.69.124 (192.168.69.124)  389.960 ms  826.775 ms  456.718 ms
7  217.39.0.2 (217.39.0.2)  447.121 ms  462.134 ms  638.253 ms
8  192.168.2.1 (192.168.2.1)  604.610 ms  253.408 ms  981.926 ms
9  217.41.219.192 (217.41.219.192)  1424.383 ms
    217.41.219.194 (217.41.219.194)  1813.398 ms  917.719 ms
10  acc1-10gige-0-0-0-5.l-far.21cn-ipp.bt.net (109.159.249.78)  1005.031 ms
    acc1-10gige-0-3-0-4.l-far.21cn-ipp.bt.net (109.159.249.120)  1755.681 ms
    acc2-te0-1-0-5.l-far.21cn-ipp.bt.net (109.159.249.204)  847.683 ms
11  core3-te0-0-0-20.faraday.ukcore.bt.net (109.159.249.169)  408.725 ms
    core3-te0-2-0-20.faraday.ukcore.bt.net (109.159.249.129)  2519.374 ms
    core4-te0-0-0-21.faraday.ukcore.bt.net (109.159.249.175)  1854.664 ms
12  * core1-pos0-8-0-8.ilford.ukcore.bt.net (62.6.201.225)  3705.343 ms
    host213-121-193-139.ukcore.bt.net (213.121.193.139)  442.141 ms
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
traceroute: Warning: bbc.co.uk has multiple addresses; using 212.58.244.18
traceroute to bbc.co.uk (212.58.244.18), 64 hops max, 52 byte packets
1  10.14.183.1 (10.14.183.1)  464.133 ms  899.820 ms  425.752 ms
2  192.168.68.34 (192.168.68.34)  417.300 ms  264.248 ms  1260.033 ms
3  192.168.240.2 (192.168.240.2)  562.453 ms  783.068 ms  1304.356 ms
4  192.168.134.2 (192.168.134.2)  2702.848 ms  1461.612 ms  949.871 ms
5  192.168.71.45 (192.168.71.45)  1106.927 ms  2677.284 ms  1919.951 ms
6  192.168.69.124 (192.168.69.124)  1236.789 ms  4969.255 ms *
7  * * *
8  192.168.2.1 (192.168.2.1)  2638.364 ms  4284.724 ms *
9  * 217.41.219.192 (217.41.219.192)  3386.737 ms  3426.437 ms
10  acc1-te0-0-0-12.l-far.21cn-ipp.bt.net (109.159.249.84)  2428.655 ms
    acc1-10gige-0-7-0-5.l-far.21cn-ipp.bt.net (109.159.249.86)  385.462 ms
    acc1-te0-0-0-21.l-far.21cn-ipp.bt.net (109.159.249.94)  212.819 ms
11  core4-te0-10-0-19.faraday.ukcore.bt.net (109.159.249.13)  1446.901 ms
    core4-te0-12-0-20.faraday.ukcore.bt.net (109.159.249.153)  347.203 ms
    core3-te0-10-0-20.faraday.ukcore.bt.net (109.159.249.137)  575.001 ms
12  62.6.201.213 (62.6.201.213)  418.376 ms
    peer2-xe8-1-0.telehouse.ukcore.bt.net (109.159.255.101)  253.834 ms
    peer2-xe8-1-1.telehouse.ukcore.bt.net (109.159.255.103)  493.915 ms
13  * * *
14  * * *
15  * * *
traceroute to bbc.co.uk (212.58.246.104), 64 hops max, 52 byte packets
1  * 10.14.183.1 (10.14.183.1)  4953.159 ms *
2  192.168.68.34 (192.168.68.34)  3790.777 ms  2860.239 ms  3584.808 ms
3  192.168.240.2 (192.168.240.2)  3040.995 ms  3304.856 ms *
4  * 192.168.134.2 (192.168.134.2)  3330.956 ms *
5  * * *
6  192.168.69.124 (192.168.69.124)  2734.849 ms  1358.812 ms  982.379 ms
7  217.39.0.3 (217.39.0.3)  1320.174 ms  686.916 ms  1188.933 ms
8  192.168.3.1 (192.168.3.1)  1164.837 ms  657.206 ms  920.973 ms
9  217.41.219.192 (217.41.219.192)  924.133 ms
    217.41.219.194 (217.41.219.194)  583.825 ms  2996.748 ms
10  109.159.249.116 (109.159.249.116)  494.688 ms
    109.159.249.76 (109.159.249.76)  1677.609 ms
    109.159.249.64 (109.159.249.64)  4171.515 ms
11  core4-te0-0-0-19.faraday.ukcore.bt.net (109.159.249.47)  3826.396 ms
    core4-te0-12-0-18.faraday.ukcore.bt.net (109.159.249.17)  3589.534 ms
    core3-te0-2-0-19.faraday.ukcore.bt.net (109.159.249.5)  3228.086 ms
12  62.6.201.209 (62.6.201.209)  3768.264 ms
    peer2-xe8-0-1.telehouse.ukcore.bt.net (109.159.254.179)  2338.971 ms
    host213-121-193-111.ukcore.bt.net (213.121.193.111)  472.188 ms
13  * * *
14  * * *
15  * * *
Tags (2)
3 REPLIES 3
Message 2 of 4
Re: How do I report poor service in a BT Openzone hotspot (Starbucks, Hampstead Highstreet)?
You could try BT Openzone help desk, 0800 022 3322
jmedwards
Message 3 of 4
Thanks for the suggestion, but unfortunately useless: they can't seem to break out of the "Let's try restart your Wifi adapter / restart your computer" script (and no, I am not going to walk through those steps).
Message 4 of 4
Perhaps you can persuade Starbucks to power cycle the router. to see if it helps, provided they are not using it for their terminals.
If its a BT Business broadband connection, they may simply be using all of the bandwidth within the business itself. Openzone has a low priority.
