mikechallis
Newbie
Message 1 of 12
How do I switch off guest access (BTWifi-with-FON) on my Home Hub 4 router?
I believe there's a way to switch the guest access feature off - BTWifi-with-FON keeps confusing my phone when I switch it on in the morning. Any help much appreciated!
Mike
11 REPLIES 11
Message 2 of 12
Re: How do I switch off guest access (BTWifi-with-FON) on my Home Hub 4 router?
you would need to opt out of BTWIFI then you would not be able to use the facility when out and about  https://www.bt.com/wifi/secure/index.do?s_cid=con_FURL_btfon
can you not set your home network as the preferred conenction? I don't have a problem with my S5
mikechallis
Newbie
Message 3 of 12
Many thanks for your prompt response and link.
The link takes me to a page where there's a "Check Status" button, which takes me to another page where I'm asked for my BT internet address and password. I enter these very carefully (treble-checked!) but they are not accepted. However when I use exdactly the same items to access my email account in the usual way there's no problem. *Very* frustrating! Any ideas as to what may be the problem now?
(My email address is a btinternet.com address)
Thanks  Mike
Message 4 of 12
is that the primary email address as only primary will work
mikechallis
Newbie
Message 5 of 12
Thanks for that - I've tried the primary email address - again, very carefully - but this is also rejected. Puzzling.
Thanks,  Mike
Message 6 of 12
if you have a BTID have you tried that?
mikechallis
Newbie
Message 7 of 12
My BTID is an email address (not a btinternet.com one) - and is not accepted. Oh dear ...
Thanks for your continuing assistance!
Mike
Message 8 of 12
deleted by poster
Message 9 of 12
Login to MyBT and try this link https://www.bt.com/appsconsumeraccount/secure/BTWifiRegistered.do?ServiceName=BTWIFI&Action=DOWNLOAD
There should be an option to opt out.
Distinguished Guru
Distinguished Guru
Message 10 of 12
@mikechallis  Don't know how relevant this is but there's a problem with the BT WiFi status site. When I was migrated to BT Mail and went through all the BT ID stuff, I had to change my age-old BT password as it was deemed insecure. No problem with that except for the BT WiFi site which doesn't recognise the new password and still insists on the obsolete one. I can't find any way to update the password for the WiFi site.
