IRBertram
Newbie
Message 1 of 3
How to remove device from protected list in Netprotect
Having survived christmas and now have new machines to protect with netprotect, how do i remove the old ones so that I do not exceed my limit of 7 machines. Can't see any obvious way.
2 REPLIES 2
Message 2 of 3
Re: How to remove device from protected list in Netprotect
I wouldn't bother, you would be better using one of the free AV's.
Message 3 of 3
My advice and that of others on the forum would be to uninstall BTNetprotect. It can cause problems on some computers and is a resource hog. Do a search of the forum to see the problems. There are far better free antivirus programs available such as Avast Free and AVG Free.
If you do want to uninstall BTNetprotect use this guide and make sure you use the BTNetprotect/McAfee removal tool after you have restarted your computer.
http://bt.custhelp.com/app/answers/detail/a_id/13523
I don't know if this will help, it's how to deactivate McAfee licences so may be the same for BTNetprotect. The other thing is just to keep installing on computers until they have all been used and when you try to put it on the 8th computer it my ether install or tell you what to do to get a licence.
http://service.mcafee.com/faqdocument.aspx?id=TS10​0996
