Message 1 of 9
How to use Norton Password Manager
I have set up Norton Password Manager, Vault and set up a login with a generated secure password. It all seems to be working. Norton even prompts me when I connect my camera to download photos. I have the Norton symbol at the top right hand side of my screen
How do I do to open the login site using the generated password?
I cannot see a a way, in the vault, to open the login site using the generated password.
If I go to the login site, via my browser, it has the pre Norton password.
How do I get Norton and/or the site to use the generated password?
What am I not doing correctly? Please provide, simple, idiot proof guidance!
Any advice will be gratefully received.
8 REPLIES 8
Message 2 of 9
Re: How to use Norton Password Manager
Hi @Howie1949 and thanks for posting.
Can you post a few screen shots of the journey you're taking so the community will have an idea on what the problem might be?
Cheers
David
Message 3 of 9
I have tried to send you screen shots but they are too big for your system to cope with!
I have no idea how to make them smaller!
Message 4 of 9
Please delete the replies about the DVLA. I was just trying to see if I could get anything to work!
Message 5 of 9
I will remove those for you, as they contain personal info.
Message 6 of 9
I don't use Norton, but I suspect you are trying to use 2 password managers, your browser's built in manager and Norton. You can only use one.
Message 7 of 9
Thank you for help.
More by luck than judgement I have worked out how to open a website via Norton; what a 'faff'.
1. click Norton icon at top right of screen
2. Select Vault.
3. On bottom line of website Login box select the 'wheel' icon
4. Select 'go to site'.
5, Bingo - site opens using Norton password!
Message 8 of 9
Thank you for help.
2. Select Vault.
Message 9 of 9
Hi @Howie1949,
Thanks for letting us know you got this sorted and for sharing the answer. I'm sure that will help other community members.
Cheers
David
