Message 1 of 4
How to use a BT Hot Spot for Broadband
I am a bt broadband customer. When I was out because there was no mobile networks available I wanted to login to a broadband hotspot to use the internet but I cannot find any guidance on how to do it properly and specifically what account name and password I should use because neither my MyBT or BT e-mail ones seem to work when I selected what seemed to be a hotspot from my nearby wi fi connections.    Using a Samsung Galaxy A52 android phone.
3 REPLIES 3
Message 2 of 4
Re: How to use a BT Hot Spot for Broadband
Use your BTID username and password but make sure you select BT broadband customer in the drop down menu rather than the default BT WiFi
Message 3 of 4
Thank you....presumably this is the same BT ID and password I use to sign in to my BT accountto see bills and suchlike.
Message 4 of 4
