jgard
Message 1 of 16
Inability to activate Parental Controls
I have the same issue regarding an inability to activate parental controls and have spent untold hours to an international call centre who tell me there isn't a problem. I hope you can help
15 REPLIES 15
Message 2 of 16
RE: Inability to activate Parental Controls
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 3 of 16
Re: Inability to activate Parental Controls
Hi @jgard
Welcome to the community and thanks for your post!  I have moved your post to start your own thread as the thread you had posted on was already marked as solved.
I'm sorry for the problems you're having activating your Parental Controls and I appreciate the time you have spent trying to get this sorted out.
The community won't be able to help with this so you can send us over your details and we'll give you a hand to sort this out from here.  Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
jgard
Message 4 of 16
Please advise what details you require from me.
regards
Jim
Message 5 of 16
@jgard fill in the form that @RobbieMac mentioned. You can find it on his profile page, here is an example.
Moderator contact link image
Moderator
Moderator
Message 6 of 16
@jgard I tried calling there but missed you, I was calling to let you know that I've activated the Parental controls from my side and I wanted to ask you to check if you can now manage them in on the MY BT website? Please can you post back to let me know if this has been sorted?
Community ModeratorNeilO
Kudos”Kudos”
jgard
Message 7 of 16
No, nothing showing. Still a message that says 'can't be activated, come back in 15 minutes'
Jim
Moderator
Moderator
Message 8 of 16
Hi @jgard,
Thank you for posting back. I'm sorry the Parental Controls still aren't working. I've let @NeilO know and he'll be in touch later on today.
PaddyB
Community ModeratorPaddyB
Kudos”Kudos”
Moderator
Moderator
Message 9 of 16
@jgard I'm really sorry about that, I've enlisted the help of our parental controls specialists to get this sorted.
Kudos”Kudos”
jgard
Message 10 of 16
Hi - I've logged in again today and it still isn't working. Any ideas?
Jim
