Newbie
Message 1 of 1
Incorrect Error message re BT Cloud which stops downloads
I get the message "We can't find this file on BT Cloud. Check you havn't moved or deleted it." and " Expected status code in (200-299,416) got 404"
The file in question is in BT Cloud and I can even download it from the web.
This error message stops both downloads and uploads from my MacBook Pro. My iMac works correctly with BT Cloud.
How can I remove this message and problem?
