colb
Message 1 of 3
Installing Norton on Android Phone
I have successfully installed norton on my PC's, but when I try to do the same with the phone, I cannot dowload the software directly.
The download link takes me to the Google Play site and the old BT Virus Protect app, not the Norton app.
Does anyone have any ideas on this?
2 REPLIES 2
Graham18
Message 2 of 3
Re: Installing Norton on Android Phone
You probably need to just be patient  -  I had to wait two days before I was able to install Norton on my phone.
It would be helpful if this was flagged up when putting Norton onto a PC  -  or if it is flagged up somewhere, making it much more obvious.
colb
Message 3 of 3
ok thanks
