Newbie
Message 1 of 4
Is it possible to move the BT Cloud sync folder
I want to move my BTCloud sync folder to a different drive rather than under my user name on C:.  Is this possible and if so, how is it done?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Is it possible to move the BT Cloud sync folder
Hi @RogerAF and thanks for posting.
Can you take a look at this cloud thread and let me know if it helps?
Cheers
David
Newbie
Message 3 of 4
Hi David.  That thread gave me all I needed to know.  Thanks a lot.
Roger
Moderator
Moderator
Message 4 of 4
Great to hear that @RogerAF. Thanks for letting me know.
All the best
David
