Salmonfish72
Message 1 of 4
Joining BT FON? will this slow my home WiFi?
If I activate BT Fon Hotspot around my residence by selecting to opt through my BT internet address on my BT Broadband Router (Home Hub 3) to activate BT FON hot spot, will it slow down my Home WiFi net work?
What is the benifit in activating BT Fon Hot sopt by allowing my BT Home Hub 3 to create a bandwith of my broadband?
regards
3 REPLIES 3
Message 2 of 4
Re: Joining BT FON? will this slow my home WiFi?
No will not affect your home network and shouls anyone use the btfononnection the home network gets priority
by activating btwifi which is normal you benefit from being able to connect to hotspots when out and about
Dippu
Message 3 of 4
Activating BT Fon will have an affect on your bandwidth but it should be only slightly, having said that, I noticed that my hub became unreliable in terms of connection and therefor opted out again. This restored reliability.
Going back to bandwidth, yes it will affect it.
Distinguished Guru
Distinguished Guru
Message 4 of 4
There's confirmation from BT here that imj's answer is correct.
