Steveee
Message 211 of 354
Re: MacOs 11 compatibility with Virus Protect no j
@occoldman What version of BT VP are you using. I have version 4.10.1.0 and haven’t experienced any issues.
Alnorwich
Message 212 of 354
I have it running on 1 Mac okay, but it absolutely refuses to run on another. It's not an old machine either.
occoldman
Message 213 of 354
Hello Steve,
Yes, I'm also using 4.10.1.0 so it's strange that it should perform differently.
ronl95
Message 214 of 354
petereng
Message 215 of 354
Exactly the same for me
petereng
Message 216 of 354
Yes it does for a while and then stops, at least it stops for me
Watkinmc
Message 217 of 354
I have installed the new version from MyBt but every time I run a scan using BT Virus Protect my MAC crashes and a report is sent to Apple.  Is that common as well?
occoldman
Message 218 of 354
Good afternoon watkinmc and a happy New Year to you.
Hopefully, by this time next year we will have fully functioning antivirus software.
With regard to your specific question, I can run a full scan without it crashing. I have run full scans several times over the past four weeks and there has been to problems.
Regards  occoldman
kenvangie
Message 219 of 354
This has now been going for so long and still has not been sorted out. How much longer is this going to take and how much compensation are you going to give everyone for not being able to use Mcafee properly as we are paying for only part of the product ?
Steveee
Message 220 of 354
@SeanD  any update on planned release of the firewall fix?
