Confused_User
Message 1 of 13
Making calls using bluetooth
I use a bluetooth headset whilst out & about and can make/receive calls over the mobile phone network without any problems.
However, if i detect a WiFi signal and make a call with the SmartTalk app it refuses to use the bluetooth headsrt that is connected and I have to talk using the mpobile phone in its normal manner instead.
Is there a setting I am missing or is this a design fault?
12 REPLIES 12
Message 2 of 13
Re: Making calls using bluetooth
IMHO this should'nt be an issue...............
However, I suspect you have just discovered a new issue with the app that no one has raised yetSmiley Wink
AQ.
"Welcome to Royston Vasey - You'll never leave."
Confused_User
Message 3 of 13
Thanks - any idea how I raise this with the developers?
Moderator
Moderator
Message 4 of 13
Hi Confused_User,
Thanks for posting. I can raise this for you. Drop me an email with the details. You'll find the "contact us" form in the about me section of my profile. Once I have the details we'll take it from there.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Confused_User
Message 5 of 13
Only option in "Contact Us" is on line chat or phone - no option to email.
Can't you see the issue in my post and raise a fault??
Message 6 of 13
Did you click on Dean's name and in his profile you should see the link
Confused_User
Message 7 of 13
I clicked on David's name and just above and to the right of his picture is "Contact Us" - this takes me to a screen with technicla help, selected BT Smart Talk and the only options are on-line chat or phone us.
Why is sending an email to support so difficult??
Moderator-Retired
Message 8 of 13
Hi Confused_User,
Try mine instead :), just click my name and you should see an "about me" section, there will be a contact link there.
Cheers,
Chris
BT Mod Team.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Confused_User
Message 9 of 13
I must be going blind - I cannot see a contact me link on your's or david's link!!
Moderator
Moderator
Message 10 of 13
Strange!!.... can you try again?
Cheers
David
Kudos”
