NeilO
Moderator
Moderator
Message 11 of 20
Re: McAfee reinstalling problem when told a restart in required
Hi @thewheelshavecomeoff I'm sorry to see you're having problems with the BT Virus protect service.  I've sent you a Private Message with details on how you can get in contact with the mod team and we'll raise a fault to get that looked into.
Message 12 of 20
hi Neil0
tried to send a private message reply but its come back with awarning
You have reached the limit for the number of private messages that you cansend now
Mike
Message 13 of 20
able to send it now
Mike
JohnC2
Moderator
Moderator
Message 14 of 20
Hi @thewheelshavecomeoff  Sorry you had a problem initially sending the PM. I've checked and we have received it and one of the team will be in touch soon to help you with this.
Cheers
John
Message 15 of 20
AS i have not heard anything from a member of the team I thought I would have another  go but to no avail.
I have rerun every McAfee tool that is in the box to delete old versions, cleared temp files and cache.
This is true i did have to download on that day but I am mystified where it comes from??????
I then click on Agree and download and  after a few moments i get the message below.
I click close and restart my PC and when it boots up nothing happens.
Mike
NeilO
Moderator
Moderator
Message 16 of 20
Hi @thewheelshavecomeoff I'm really sorry you were not contacted back. Can you try running the McAfee Virtual Technician. If that doesn't work I've sent you a Private Message with details on how you can get in contact with the mod team and we will get back to you.
Message 17 of 20
Hi Neil0
Tried to send a private message but it has reached the limit of private messages try later
Mike
JohnC2
Moderator
Moderator
Message 18 of 20
Hi @thewheelshavecomeoff  sorry about that. Try again now as this issue usually clears after a few minutes. Let me know if you still can't reply to Neil.
cheers
John
Message 19 of 20
just the same, when I do  do send message a red warning abot HTML being removed and when I send again i get
You have reached the limit for number of private messages that you can send for now. Please try again later.
Mike
JohnC2
Moderator
Moderator
Message 20 of 20
Hi @thewheelshavecomeoff  thanks for trying again and sorry it's still not working. Would you try switching off your private messages for a few minutes and then switch them back on and try again?
John
