Message 1 of 11
McAfee to Norton Update
Do you not think BT should suspend temporarily the McAfee to Norton Update and get it sorted out before offering the update to customers and causing headaches all round ??
Just saying.......
10 REPLIES 10
Message 2 of 11
Re: McAfee to Norton Update
What's wrong with it? My update went really well. Simply uninstall one and install the other !
Message 3 of 11
Hi @atttim and thanks for posting.
It should be an easy process to switch them over as @ZooBurner has mentioned. If you have any problems let me know and I'll be happy to help.
Cheers
David
Message 4 of 11
I am trying to change from McAfee to Norton on my Android 7.1.1 without success.  Following the instructions from MyBT I finally get directed to a download of BT Virus Protect on PlayStore which only downloads the old McAfee app.
The app was last updated on 7/3/19 whereas on my tablet it shows to be updated on 19/11/21 by Norton.  Deleting and reinstalling the app only loads the old version again.  No updates are available on my phone.
Any words of wisdom?
Message 5 of 11
I'm trying to Upgrade on an iMac and get a "Classic environment is no longer supported" message and a Safari "No available application can open it" message when I try and action the Norton installer download.
Message 6 of 11
Congratulations !!
It appears quite a few appear to be having problems ......
Message 7 of 11
Hi @gilly3, welcome to the forum, and sorry you're having trouble moving to Norton.
As you are on Android 7.1.1 you are taken back to the McAfee version. For Norton, you must be running Android 8.0 or later.
John
Message 8 of 11
Hi @Geoph, welcome to the forum, and sorry you're getting these errors trying to change over to Norton.
Are you using a version of Mac older than 10.14?
Cheers
John
Message 9 of 11
I’m running Mojave 10.14.6, which is the latest release for Mojave.
Message 10 of 11
I have Android 11 but I still cant download  BTs Norton package.   It tells me that Chrome is not supported!!
