Message 11 of 15
Re: McAfee to Norton not working
Sorry but what the techie told you isn’t true, last week a techie took over my Mac and deleted numerous hidden McAfee files, my Mac now has Norton on it and it’s working fine.
Message 12 of 15
Ok, thanks for letting me know. I am spending time at the moment trying to find any elusive files! I'm running 14.6. Wonder if I should move up to 15?
Message 13 of 15
Hello 570dpj  my Mac 13.6 so you don't need to upgrade
This should help you
Go > Applications > Application Support > McAfee > Trash the Folder.
Go > Computer > Library > McAfee> Trash the Folder
Go > Computer > Library > LaunchDaemons > Type 'McAfee’ >Trash all found Files.
Go> Computer > Library > PreferencePanes > Type 'McAfee’ Search Bar > Trash all found Files.
Go > Computer > Library > LaunchAgents > Type 'McAfee’ in the Search Bar > Trash all found Files.
Last Step: Empty the Trash > Perform a System Restart.
Message 14 of 15
Thank you. Tried all that and no difference. I still have the True Key app, but can't delete that yet!
Message 15 of 15
I have manually removed McAfee and removed the LaunchAgents.  I restarted my mac and launched the installer but it hangs as it did before.  All I get is a blank page with 'My Norton' followed by 'Installer'.  I have restarted several times and done searches for any orphaned apps or code lines but nothing is found.
Having used Norton in the past I was not that impressed so not sure why BT moved from McAfee.  If this is not resolved soon I will source my own anti-virus.
