Mandyb1965
Message 1 of 10
Mcafee
I had McAfee on my laptop and mobile phone but then my phone broke and I couldnt log on. I brought a new phone and because I cant cancel it on my old phone I cant have it on my new phone as it says I have to remove off of that phone first as I am at my limit on 2 devices. How can I get BT to remove it from my old phone that doesn't work so that I can have it on my new phone
9 REPLIES 9
gg30340
Message 2 of 10
Re: Mcafee
Have a look at this link and in particular page 15. It might help.
https://www.bt.com/content/dam/bt/help/legacy/Virus_Protect_Userguide_v2.pdf
Mandyb1965
Message 3 of 10
Re: Mcafee
Hi, thank you but I cant log on to the device to reset it. I need McAfee to remove the device I added. When I try to download to my new phone it says I have to remove it from my old phone but it is broken. Thanks
gg30340
Message 4 of 10
Re: Mcafee
Log onto your MyBT on another device, it doesn't need to be your old phone, then follow page 15
ChrisB
Expert
Message 5 of 10
Re: Mcafee
Don't put McAfee on your phone it's just bloatware. On your laptop use Windows Defender it's part of Windows, lightweight, and reliable.
Mandyb1965
Message 6 of 10
Re: Mcafee
It says I am at my limit on devices
gg30340
Message 7 of 10
Re: Mcafee
Did you read the link I posted?
Select the device you want to manage ie your old phone, and as far as I am aware you should get an option to deselect it.
Mandyb1965
Message 8 of 10
Re: Mcafee
No it doesn't give me the option , that is what I am having the problem
Mandyb1965
Message 9 of 10
Re: Mcafee
Ok what's best for my phone please?
pottyperson
Distinguished Guru
Distinguished Guru
Message 10 of 10
Re: Mcafee
There are plenty of reviews online. For what it's worth, I've used Lookout for years without issues.
