Flimsynight
Newbie
Message 1 of 2
Mini Home Hotspot 600 help
Hi, hope someone can help. We have an extender in an office in our house that was working just fine (40MB ish download speeds). Unfortunately suddenly we are now getting a maximum of about 5-6 MB download speed in all sockets in that room. The same extender works fine in other rooms. This office room was a garage and was converted about 6 months ago, but like I said we were getting good speeds up to very recently... thanks in advance!
Tags (1)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Mini Home Hotspot 600 help
Hi @Flimsynight and welcome.
Take a look through the Mini Wi-Fi Home Hotspot 500/600 FAQs and let me know if that helps.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
