johng1959
Message 1 of 6
Mobile connects to BT-Fon rather than BTHOME SIDs when at home
Why does my mobile connect to Fon on occasions rather than one of my BTHOME SIDs when I'm at home?
How can I stop it from doing this?
5 REPLIES 5
Distinguished Expert
Message 2 of 6
Re: Mobile connects to BT-Fon rather than BTHOME SIDs when at home
Is it Android or iPhone?
The usual fix is to go into wi-fi settings, and you will see that you are connected to Fon.
Select the option to "forget this network"....Then select your own SSID.
johng1959
Message 3 of 6
Hi
It's an android phone.
I've tried to "forget" BT-Fon but it still connects to it, not every time just occasionally enough to be annoying.
Message 4 of 6
If you are using the BT WiFi app, there is an option to give priority to your home connection.
johng1959
Message 5 of 6
I have the "Automatically connect me to my home hub when in range" ticked - is that what you mean?
Despite having the app installed and my login details saved within it, it never automatically connects me to Fon. However I don't want it to do when I'm at home.
Message 6 of 6
That is the option. I find it works just fine on my old Android phone, however the nearest wifi hotspot is at the end of the road, but it still shows as a usable signal.
My router does not transmit BT Wifi anyway.
