SGunnUK
Message 1 of 6
My BT Cloud License expired on renewal
I had the exact same problem after I renewed by broadband on 18/09/14. I have spoken to BT customer & technical support twice now and they were unable to locate or correct the problem whist I was on the phone. Technical support advised that they have created a call and I should here back from them within 48 hours.
I also noticed on My BT that it says 'Sorry you've decided to leave BT' on both Email & Cloud.
Any help or suggestions greatfully received.
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: My BT Cloud License expired on renewal
Hi SGunnUK,
Welcome and thanks for posting. I can look into this for you if you wish. Drop me an email with the details. You'll find the "contact us" form in the about me section of my profile. Once I have the details we'll take it from there.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
SGunnUK
Message 3 of 6
Thank you David,
I am also getting the warning message about my email account.
Sorry you are leaving BT Broadband. Your email access will stop on 19/10/2014
If you want to continue your email service, you can upgrade to BT Premium Mail for only £1.60 a month. Otherwise your email address and all your messages will be deleted on 26/10/2014
I'd appriciate this being looked at & resolved ASAP as you can imagine not have email will be a major inconvienience.
Thanks in advance.
SGunnUK
SGunnUK
Message 4 of 6
I've emailed BT with all the details, reference number is 140927-*****.
SGunnUK
Message 5 of 6
Hello David,
I have emailed the moderators as suggested, awaiting their reply.
Kind Regards,
SGunnUK
Moderator
Moderator
Message 6 of 6
Thanks for confirming that SGunnUK. We have your email and will be in touch soon.
Cheers
David
Kudos”Kudos”
