Anonymous
Not applicable
Message 11 of 32
Re: My BT app not working
AndrewRMason
Message 12 of 32
Also iPad 4, iOS 10.3.3.
App Store says requirements are  iOS 9.0 or later.
BT help pages say iPad 2 or later.
Do someone need to have a word with whoever writes the App Store info?
Anonymous
Not applicable
Message 13 of 32
I couldn't comment on that but if your machine is on the list I posted earlier then you won't be able to update as there isn't a later iOS for machines that are.
AndrewRMason
Message 14 of 32
Thanks for the help. My iPad isn’t on this list of vintage products, but it is a 32 bit machine, so I suspect this may be the problem. I guess it may well be on the next list they publish.
AndrewRMason
Message 15 of 32
Heres a useful list of specs including whether a device is 32 or 64 bit
https://blakespot.com/ios_device_specifications_grid.html
Anonymous
Not applicable
Message 16 of 32
Did you check the Obsolete products further down the list
AndrewRMason
Message 17 of 32
Do you mean this section?
”iPad products vintage worldwide
  • iPad [original]
  • iPad 3G
  • iPad (3rd generation) Wi-Fi
  • iPad (3rd generation) Wi-Fi, Cellular
  • iPad (3rd generation) Wi-Fi, Cellular (VZ)
  • iPad 2
  • iPad 2 3G
  • iPad 2 3G (Verizon)
iPad products obsolete worldwide
  • iPad Wi-Fi
  • iPad Wi-Fi + 3G
  • iPad Wi-Fi + 4G
  • iPad Wi-Fi + 4G (Verizon)”
Is my “iPad 4th generation” really an “iPad Wi-Fi + 4G”?
Anonymous
Not applicable
Message 18 of 32
Sadly, yes. If yours is an iPad 4 then it is obsolete and you will not be able to download any iOS updates later than 10
Anonymous
Not applicable
Message 19 of 32
@SeanD
I've just borrowed an iPad 4 from a friend to test this, all I can say is very sloppy coding.
I was allowed to download the MyBT App from the Apple Store and install it but it crashes when launched just as @AndrewRMason  describes.
If, as I suspect, this app requires iOS 11 or greater then it should have thrown up an error message when I tried to download/install it, this might be worth bringing to the attention of the development team.
Playford1651
Message 20 of 32
But then why did the previous update work alright if my iPad is now so out of date?
