Simie1973
Message 1 of 2
My bt app Speedtest
Hi since i had a fault on my line which has now been corrected my BT app will no longer let me do a speed test i have deleted the app and reinstalled it yet speed test starts and the fails every time....any ideas ??
Tags (1)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: My bt app Speedtest
Hi @Simie1973,
If you take a look at I'm having problems with the My BT app, you'll find some useful information that will help with the My BT App.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
