Message 1 of 7
MyBT android app keeps crashing
I have the latest version of the app but it keeps crashing.
Shows the error message and tells me to restart the app.
I have an Xperia 5 and I'm running the latest android 11 from Sony.
I do have pretty tight controls on my DNS but can't see anything blocked that relates to BT sites.
Anything I should be trying?
6 REPLIES 6
Message 2 of 7
Re: MyBT android app keeps crashing
Hi @Rabit, welcome to the forum, and thanks for posting.
Would you try uninstalling the app and installing it again and see if the problem persists?
Cheers
John
Message 3 of 7
Yes I'm afraid it still does.
I even tried a reboot in between but still no joy.
Message 4 of 7
Hi @Rabit, thanks for trying that, and sorry it's still not working.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you get this fixed.
Cheers
John
Message 5 of 7
Can I ask if/how this got resolved?  I'm having exactly the same issue - and yes I have already uninstalled and reinstalled the app.
I've not used the app for ages but then when I did today it told me it needed to be updated.  I ran the update and it now just sticks in a loop of crashing, saying to restart it and repeat ad-infinitum!
What can I do please?
Message 6 of 7
@JohnC2 and @Rabit . I'm sorry, realise I should have tagged you with the question
Message 7 of 7
I got nowhere with this either. There's nothing on the app worth using anyway so I just gave up.
If I need my bills I go to the website.
