Message 1 of 5
Norton app causing issues
I have downloaded Norton app, it's stopping me seeing my Facebook pages properly saying go back or continue but nothing happens. I also can't do Google searches without it saying I can't get onto the website "not available" didn't have these problems with McAfee, should I install it off my phone Android 12 ?
4 REPLIES 4
Message 2 of 5
Re: Norton app causing issues
The reason you can't see Google is very probably because you've enabled Norton Safe search, disable it and you should be OK.
Think of it as Nortons answer to Smart Setup on the BT routers in a contest for the worst software ever conceived
Message 3 of 5
Thank you
Message 4 of 5
Thanks Les I preferred mcafee
Message 5 of 5
I'm not keen on McAfee but then again I've never been impressed with Norton, it's a case of 6 of one, half a dozen of the other as far as I'm concerned.
I try them out just out of curiosity and then remove them, if you're running Windows 10 or 11 then I would suggest that Windows Security is as good, if not better, than both
