Message 1 of 4
Norton protect by BT compatability if running Kaspersky
BT are bundling "Norton Protect" with future BT broadband deals. I currently run Kaspersky. Are they going to clash and cause problems? If so, given that I like using Kaspersky, how do I solve the problem?
3 REPLIES 3
Message 2 of 4
Re: Norton protect by BT compatability if running Kaspersky
It's not good running 2 different virus protection programs on same machine so just don't install norton
Message 3 of 4
That's what I was thinking.....but, at this stage, Imy not sure that I will get the option to uninstall  (or even better....deny installation)  Norton. Having said that, it's possible I might better running the Norton and uninstalling  Kaspersky  (though unlikely). I'm guessing rejecting  Norton must be an option....it must be PC based (rather than running on the router). In any event I have several PCs  and laptops with Kaspersky  on each. (You'll appreciate that I'm way off being computer literate)
Message 4 of 4
You will have the option of installing it. If you don't want to then don't.
