Message 1 of 26
Norton won’t download
I’ve tried multiple times to update to Norton via MyBT on my iPhone. Norton keeps saying “Norton Security cannot be installed on your operating system …. However it can be installed on the following operating system:….  IOS”.  But I’m using IOS !!!
25 REPLIES 25
Message 2 of 26
Re: Norton won’t download
Norton does not install on mobile phones. It will install on a Desktop, iMac oe a Tablet.
Message 3 of 26
Thanks for clarifying.  I’ve now got a bit further using my iPad. I’m into Norton but can’t install. When asked to “Agree & Download” the next page says “Follow the installation instructions below”.  Below that is a “Restart Download” button which doesn’t work
Message 4 of 26
Hi @jillian22 I'm sorry the BT Virus Protect software is NOT available on iOS devices however you can use the Norton Password Manager on an iPhone/iPad if you wish.
Neil
Message 5 of 26
BT failed to inform us that Norton virus protection from BT is not compatible with iMac.
Message 6 of 26
Thank You. This is correct.
Message 7 of 26
Hi @drabdulbasit That is incorrect, BT Virus protect is compatible with iMac however you need to ensure that it is running Mac OX X 10.10x or later.
I have responded to your other post with information to follow for the error you are getting.
Neil
Message 8 of 26
After 2 days of trying different methods on my iMac running Mac OS High Sierra version 10.13.6
After locating some files as shown in pic using Free APP CLEANER & Uninstaller
My Norton Installer is running on my iMac and InstallingDeviceSecurity.
I hope it works.
Message 9 of 26
So BT’s letter promising “Your BT broadband will continue to include security tools and support to help keep you and your family safer online” …. and which ends “Putting your safety first, The BT Team” isn’t worth the paper it was printed on? Broadband customers using IOS deserve to be warned.
Message 10 of 26
Thank you. I have now been able to install Norton on my iMac. Deleted few remaining files of McAfee from Finder.
