nickwardes
Message 1 of 10
Parent controls "Sorry, something went wrong. Please try again later."
Hi.
We have never used this as we don't have any children at the house, but it has seemed to have turned on, on its own.
When i go to turn it off it says: Sorry, something went wrong. Please try again later. under where the controls should be.
We are having sites blocked which are never usually blocked and we cannot get access when trying to unblock it. It says this:
You are not authorised to manage this Parental Controls service, please contact the account holder.
Mother has called BT support and they couldnt walk her through a fix because she doesnt understand how to do this stuff.
I am 100% certain that it is a problem on BT's side as it is the website though.
I also spoke on live chat and they couldnt find a fix.
Any help would be great, thanks.
9 REPLIES 9
Moderator
Moderator
Message 2 of 10
Re: Parent controls "Sorry, something went wrong. Please try again later."
Hi @nickwardes,
To deactivate the Parental Controls the BT Account Holder need to long into their primary BT ID.
You can find out how to do so, by take a look at - BT Parental Controls - 'How to...' guide
Let me know how you get on.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
nickwardes
Message 3 of 10
Thanks for the reply @PaddyB, This has been done but like i said it says, "Sorry, something went wrong. please try again later"
nickwardes
Message 4 of 10
Moderator
Moderator
Message 5 of 10
Hi @nickwardes,
Thank you for getting back to me.
If you send me in the BT Account details. I'll take a look at this for you. You can send me in the details using the "Contact The Mods" link found in my profile.
PaddyB
Kudos”Kudos”
nickwardes
Message 6 of 10
Thanks @PaddyB. Have put in a Query now.
nickwardes
Message 7 of 10
Hi,
Today we had another call from a chap trying to make us troubleshoot again. As you have seen on the screenshot, there is nothing that we can actually do with the settings, i have been through all the troubleshooting with BT live chat and we are still at where we are now. It's a problem with the website and they don't seem to understand that there is nothing we can do with it and that they have to fix it themself.
The only progress we feel we have made is when you gave us a ring (thanks for calling by the way @PaddyB), The other people who keep calling seem to be taking us around in circles.
I was wondering if you could pass on to them that we have been through all the troubleshooting and that we can't actually do anything with the settings. It's getting fustrating for us to have these calls from them when they don't seem to have a clue what they are talking about or what the actual problem is.
Moderator
Moderator
Message 8 of 10
Hi @nickwardes,
I can see that it's @NeilO dealing with this for you, not @PaddyB Smiley Happy
Can you check it for me now please? It should be off.
DanielS
Community ModeratorDannyS
Kudos”Kudos”
nickwardes
Message 9 of 10
Long story but i was communicating with @PaddyB.
You have fixed it, thanks very much. @DanielS
Thanks to all the mods involved, did a much better job than all these people phoning up. 🙂
Moderator
Moderator
Message 10 of 10
You are very welcome @nickwardes. I'm glad I was able to help you.
I'll let @NeilO know when he returns to office tomorrow Smiley Very Happy
DanielS
Kudos”Kudos”
