pinarguney
Newbie
Message 1 of 8
Parental Controls are not working
Hi ,
Could you please help to correct this issue?
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: Parental Controls are not working
Can you supply more details such as how are they not working. Are the showing in your MyBT. What happens when you try to activate them etc etc.
pinarguney
Newbie
Message 3 of 8
Hi ,
It looks as activated, however when I make a test, all the web content is visible . I have tried to restart the modem but didn't make a change.
Message 4 of 8
pinarguney
Newbie
Message 5 of 8
Hi,
I have tested parental control on my ipad and iphone using BT wifi . They working fine as expected. It was not allowed to enter to any adult sites
But  the Macbook air doesn't recognize any parental control . It is allowing to access to all adult content. What could be the reason? Why is it bypassing it?
Kind Regards
Message 6 of 8
Do you have a VPN set up on your Macbook?
pinarguney
Newbie
Message 7 of 8
Hi,
To be honest, I don't know. How can I check that?
Message 8 of 8
Is your Mac a company owned device, if so it will most likely have a VPN set up.
If not you would have to have set it up to use a VPN. See link how to check the settings to see if one is being used.
https://www.howtogeek.com/216209/how-to-connect-your-mac-to-any-vpn-and-automatically-reconnect/
