Internet-Amy
Message 21 of 25
Re: Parental Controls greyed out - terrible customer service!
Hi Stephanie,
Still no luck 😞 just tried on my work machine and my mobile. Still the same fault. Cleared cache and cookies too.
Community Manager
Community Manager
Message 22 of 25
@Internet-Amy thank you for checking, I'm really sorry you're still getting an error message. The team is back on the case, there's a lot going on behind the scenes here. I'll update you as soon as I can.
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Community Manager
Community Manager
Message 23 of 25
@Internet-Amy there's been a lot of activity here, can you try again now, and if you still get an error message can you post up another screenshot of it?
Thank you for including a screenshot each time, it's been helpful the team to see what you're experiencing.
Kudos”
Internet-Amy
Message 24 of 25
Hi Steph,
I'll send a PM now but it looks promising, I can enable and adjust settings now which I've never been able to do.
Amy
Community Manager
Community Manager
Message 25 of 25
Hi @Internet-Amy thanks for getting in touch, I'm glad to hear that you can now manage parental controls 🙂
I'm sorry it took us so long to get to the bottom of it, but I'm glad it's all sorted now. Thank you for your patience throughout.
Kudos”
