Message 1 of 2
Parental Controls not working and won't activate
Help. when I go to a website, sometimes it comes back as saying blocked due to parental controls light touch.
I have tried switching the parental controls on then off then on again without success.  the security tab in mybt.com says to activate parental controls and when I hit it the tab it then says they will be activated within 2 hours, but two weeks later still nothing.  They are obviously active despite the suggestion they are not as they are blocking the website I wish to visit (a local online beer seller).
Anyone able to help please?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Parental Controls not working and won't activate
Hi @Jackal999 and welcome.
Thanks for posting about your parental controls problem. This isn't something the community will be able to fix so I've sent you a private message so you can get in touch. Drop me a reply and I'll look into this for you.
Cheers
David
