Message 1 of 10
Parental Controls not working
Oh hello,
I've followed the troubleshooting guide however nothing is being blocked.
I had the same problem a while back and something needed to be done on the BT side.
Thanks!
9 REPLIES 9
Message 2 of 10
Re: Parental Controls not working
Hi @stoker82, welcome back and sorry you've got a problem with the Parental Controls again.
Has anything changed since it was last fixed? ie changed Broadband package or moved home?
Cheers
John
Message 3 of 10
Hi, I've moved to a Halo contract but the BT Hub and WholeHome haven't changed.
Message 4 of 10
Hi @stoker82, thanks for posting back and that change should not affect the Parental Controls.
Would you check and confirm that you are using BT's DNS settings and let me know.
Cheers
John
Message 5 of 10
Thanks for this- I'm not sure how or when that was changed!
Message 6 of 10
Hi @stoker82, thanks for checking that out, and glad it's fixed things for you 🙂
Cheers
John
Message 7 of 10
Hi I appear to be having the same problem
Message 8 of 10
Hi @gooleys welcome back to the community, I'm sorry to see you're experiencing problems with your parental controls. Have the parental controls ever worked and has anything changed recently?
Neil
Message 9 of 10
Yes they worked at my old address but since I moved to new address a week ago they stopped working even though I have put on strict
Message 10 of 10
Hi @gooleys thanks for getting back to me, I've seen this happen before and we'll need to raise a case to get the parental controls system updated with your new broadband details.
I'll send you a private message so you can send over your details to the moderation team.
Neil
