blueriga
Message 1 of 10
Parental Controls
I have used parental controls to block access to Youtube.  It works fine EXCEPT that on one of our tablets it is possible to get Youtube ! All other devices (laptop, PC, smartphones, other tablets) block Youtube.  I have checked that the rogue tablet is connected to the internet via the BT hub and our home network and there is no 4G connection. Can anyone suggest what is happening here ?  Children have, of course, discovered the loophole and I am having to hide the tablet in question ! Thanks
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Parental Controls
Are you sure its not connecting to BT Wifi/FON, if the BT Fi app has been installed?
blueriga
Message 3 of 10
I have checked that in the tablet settings and it shows it is connected to the BT Home Hub.  BT Fon is showing in Settings as available but not connected.   I have just found another older tablet and that too is connecting to Youtube. Thanks for replying.
Keith_Beddoe
Message 4 of 10
Do you have BT Protect enabled on your account, as the only thing I can thing of is that the tablets are using Google DNS and not BT DNS.
If BT Protect is enabled, then this would be blocked, as it stops other DNS severs being used. So if BT Protect is not enabled, then it would be a good idea to enable it.
blueriga
Message 5 of 10
BT Web Protect is enabled and on (just checked)
Keith_Beddoe
Message 6 of 10
Have you checked that YouTube is still blocked on a PC, as it may simply be that Parental Controls have stopped working?
blueriga
Message 7 of 10
Just checked and yes Youtube is blocked on PC, laptop and smartphones
Keith_Beddoe
Message 8 of 10
Then you may find that the tablets are accesing via a different domain.
Are you blocking googlevideo.com as well as youtube.com and youtube.co.uk ?
also youtu.be
blueriga
Message 9 of 10
That's worked !  Thank you for your perseverance - it is much appreciated.  Still don't know why it was only the tablets affected, but very pleased not to have to hide the tablets any more.  Thanks again
Keith_Beddoe
Message 10 of 10
Excellent Smiley Happy
Tablets rely on internal apps, which do not access youtube the same way as PCs, so you have to block all domain combinations.
