grandmacaz
Message 1 of 11
Parental control problem
I got prenatal control put on my Bt Froday set times for it to come back on andit did nt went to the manage exteres and knocked it off still nothing could not get on to anything then spoke to BT and they told me to disable it did this and still nothing been on to then all day yesterday and still carnt get the boys phones or xbox working and I carnt get on to some things BT dont seem to beable to fix this can any one help.
My rooter is hub 5 andfor some reason on my computer it says Network 2.
I keep getting messegies saying
Check your proxy server or contact network administrater to make sure that the proxy server is workingBut the buys phunes and xbox anr on the hub wifi and they still carnt get on to anything help please.
10 REPLIES 10
grandmacaz
Message 2 of 11
how do I contact the Moderator
I have been trying to find a way to contact the moderator and carnt find the link to do this help please.
grandmacaz
Message 3 of 11
Re: RE: Inability to activate Parental Controls
thank you was trying to get them but carnt find the link but will look out for it now thank you.
grandmacaz
Message 4 of 11
Prenatal control problem
got your email but still carnt find out how to read the message or get to you thanks
Keith_Beddoe
Message 5 of 11
Re: Prenatal control problem
Moderator contact is by invte only.
I have moved all your posts to this thread.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK. to this thread.
They should be able to determine whether the parental controls are active or not.
grandmacaz
Message 6 of 11
thank you I will what for them to reply
RobbieMac
Moderator
Moderator
Message 7 of 11
Hi @grandmacaz
Thanks for your posts and welcome back!
Sorry for the problems you're having using Parental Controls.  The community won't be able to help with this so you can send us over your details and we'll give you a hand from here.
Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
grandmacaz
Message 8 of 11
how do I copy and past
Keith_Beddoe
Message 9 of 11
Dont post anything on this forum, just submit it to @RobbieMac via the contact form.
Keith_Beddoe
Message 10 of 11
To see the contact link, you need to view the forum in the full site view, not the mobile view.
It will look like this Moderator contact link image
