Pejate
Newbie
Message 1 of 3
Parental controls and iMessage photos
Has anyone noticed an issue with iMessage photos not working. I have parental controls on with ‘file sharing’ restricted. It worked fine until about a week ago. After some investigation if I turn off the file sharing restriction it works. Is this an intentional change? Am not sure iMessage photos meets the spirit of the category as set out in the guide.
2 REPLIES 2
TimCurtis
Recognised Expert
Message 2 of 3
Re: Parental controls and iMessage photos
@Pejate
There was a recent Apple update that affected the way iMessage handled photos. If you send 4 or more in the same message then they are sent as a fileshared link. Under 4 though they're sent as part of the iMessage.
Would this fit your scenario?
What about WhatsApp does that work OK?
Pejate
Newbie
Message 3 of 3
Hi
No not really. Single photos failed. It appears to be related to the fileshare parental controls as now this is off it works.
Interestingly I think it started after I updated to IOS 12.4 so this could be the trigger to the parental controls now blocking them.
I don’t use WhatsApp so cannot advise in the regard, sorry.
Seems to possibly be an Apple change affecting the parental control mechanism.
Thank you!
