ceefla
Message 1 of 6
Parental controls not working
Hi,
I'm unable to get these to work on my account. They are showing as "Active" and have set up a custom filter as well as blocking a specific URL for testing.
In addition I have cleared my browser cache, flushed DNS, checked DNS is being handled by the hub, restarted hub, turned controls off and on again.
I've been on to the phone to the BT cell centre but they have not been able to assist.
TIA,
Colin
5 REPLIES 5
Message 2 of 6
Re: Parental controls not working
did you check your MYBT and ensure switch on
this is BT help  https://www.bt.com/help/home/security/#/parental-controls/
ceefla
Message 3 of 6
Yes, showing as turned on.
I've been through all the BT docs and spent time on phone and chat with BT - they've conducted a remote session on my PC and everything looks fine to them.
Message 4 of 6
wonder if you have a similar problem and need mod help
https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/BT-Parental-Controls-Not-Working/m-p/19552...
ceefla
Message 5 of 6
Yes, I read that one and thought it was similar to my issue.
Do I need to wait for a mod to pick this up?
Moderator
Moderator
Message 6 of 6
Hi @ceefla
Thanks for your posts and welcome back!
Sorry for the problems you're having using parental controls.  I appreciate the time you have already spent trying to get this sorted out.  As you have spoken to a few of my colleagues and you're no further forward you can get in touch with us and we'll check this out.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
