AmandaB1
Newbie
Message 1 of 2
Parental controls not working
I have turned on BT parental controls and they are not working. My son is watching **bleep**. How do I fix this?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Parental controls not working
Hi @AmandaB1 welcome to the community and thanks for posting, I'd like to help you get this sorted.  Have the filters been set to strict? Also do you know if it is only your sons device that is still able to access content that should be blocked or can all devices still get through?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
