EEcastoff
Message 1 of 5
Parental controls wide open
Hello, I’ve had BT for nearly 2 years now. I’ve noticed Parental Controls are not working as sites like pornhub are wide open. I have reset the home hub several times. Why aren't the sites being blocked?
4 REPLIES 4
flamethrower
Message 2 of 5
Re: Parental controls wide open
Yes, I've had the same problem.
Enabling and disabling didn't fix it.
Mysteriously, after I posted here it went back to working as expected the next day. Seemed strangely coincidental.
Tags (1)
Moderator
Moderator
Message 3 of 5
Hi @EEcastoff
Welcome to the forum and thanks for your post!
Sorry for the problems you're having managing your Parental Controls service.  Have a look at this link: BT Parental Controls - 'How to' guide
Let me know how you get on with this.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
flamethrower
Message 4 of 5
EEcastoff
Message 5 of 5
I did a ‘DNS flush’ from my iPhone settings as per another post. Parental Controls working as before when using net on my phone. I need to check other devices rest of family are using including 2 teens.. Now how do you separate teens from their devices.. ?!
