DaveJFT
Message 1 of 3
Parental controls won't let me Whitelist Google Drive
Hi,
How do I Whitleist 'drive.google.com'? I have Parental Controls turned on and stopping Filesharing to prevent my 'teens' getting into all that but by default Parental Controls also seems to affect access to Google Drive. The over zealous URL filters won't let me Whitelist Google Drive (drive.google.com) so right now, just to gain uninterrupted access to Google Drive I have to allow Filesharing.
Can anyone help?
Thanks!
2 REPLIES 2
shibes
Message 2 of 3
Re: Parental controls won't let me Whitelist Google Drive
My daughter can't access her Google Drive. I switched off BT Web Protection and Parental Controls, Google Drive is then (temporarily) available. But once Web Protection and Parental Controls are re-activated, same old problem!
What's causing this?
Which one, Web Protect or Parental Control?
How to fix?
Spent an hour+ in a call Google, even they are stumped.
shibes
Message 3 of 3
Sorted! I needed to de-select "File Sharing" on the Parental Controls.
Problem shared is a problem halved - LOL
