Belson
Message 1 of 3
Parental controls
Hi,
I set up my parental controls (custom level) about 6 months ago which didn't seem to work.  They worked for a couple of hours on one device a couple of months ago, but never on anything else.
but nothing is actually blocked.
I called customer services yesterday and after much disconnecting and calling back was finally told it was being escalated to level 2, but the person didn't really seem to understand what was going on, just following the usual script.
Is there a convenient trick to getting this to work or does it need something a little more in-depth?
2 REPLIES 2
Message 2 of 3
Re: Parental controls
Have you tried restarted the home hub,and any devices connected to it?
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are a UK based team of people, who take personal ownership of your problem.
Once you get a reply, make sure that you are logged into the forum, then click on their name, you will see a screen like this. Click on the link as shown below.
Please do not send them a personal message, as they cannot deal with service issues that way.
For your own security, do not post any personal details, on this forum. That includes any tracking number you are give.
They will respond either by phone or e-mail, when its your turn in the queue.
Please use the tracked e-mail, to reply, not via the forum. Thanks
This is the form you should see when you click on the link. If you do not see this form, then you have selected the wrong link.
When you submit the form, you will receive an enquiry number, so please keep a note of it
Moderator
Moderator
Message 3 of 3
Hi Belson,
I'm sorry to see you're having problems with parental controls. Please use the 'contact the mods' link in my forum profile under the 'about me' section to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
