hungledink
Message 1 of 5
Phantom parental controls
Ive never had parental controls switched on, but today some sites are being blocked becuase im being told I have custom filters set up.
Ive never set up any filters so why might this be happening?
I tried online chat to resolve the issue but they said they would need to phone me, which they did, but promptly hung up on me.
4 REPLIES 4
Message 2 of 5
Re: Phantom parental controls
If you do not want parental controls, then you will have to uninstall them. You may have to switch them on first, then you should get the option to uninstall.
hungledink
Message 3 of 5
Tried that but they still appear blocked, even after the 2 hour wait.
Message 4 of 5
Restart the home hub and your computer.
If its a Windows computer, enter this command at a command prompt.
ipconfig /flushdns
hungledink
Message 5 of 5
Seems ok now, noticed my hub seemed to be restarting itself a few times of the past few hours though, got the hub homepage when I used the Internet a few times, but tried your suggest as well.
Thanks for the advice.
