Message 1 of 7
Problem with BT Cloud App
My IOS BT Cloud app was working absolutely fine, then a couple of days ago, when logging in I got a message saying an update was available and it had to be downloaded to continue.
I clicked the upgrade link which just takes me to the App Store where the app I already have is available. There is no option to upgrade, only open what I already have so you end up in a loop.
I tried deleting the app and reinstalling it, but it is no different. The app store is saying there is no new version.
Anyone managed to solve this problem? I primarily use BT Cloud to backup my iPhone, so it's pretty useless without the app.
6 REPLIES 6
Message 2 of 7
Re: Problem with BT Cloud App
I have to same problem. App Store just gives option to open not to upgrade. Same on iPhone and iPad running IOS 11.3.
Distinguished Guru
Message 3 of 7
Hi @AdverseTangent & @Addy,
I am sorry to read about the problems you have with the app. We are aware of the issue and we are working with Apple to identify the problem.
DanielS
Moderator
Moderator
Message 4 of 7
Hi guys,
Thanks for raising this and I am sorry that you're having problems using the BT Cloud app.  I've received confirmation that the issue is fixed now but it will take some time for things to update.  Can you keep an eye on it over the weekend and keep us posted?
Cheers,
Robbie
Newbie
Message 5 of 7
Sorry - problem still exists on my Ipad -timed at 06:27 GMT
Message 6 of 7
Hi @RobbieMac ,
BT cloud apps is working ok at time of this posting.
thanks
A
Newbie
Message 7 of 7
Checked again-all is now well. Thanks to all concerned for a quick resolution!
